hydraulic line to slave
Old 06-11-2010, 01:33 AM
phdraperinc's Avatar
Default hydraulic line to slave
Basically is there an easy way to disconnect the hydraulic line from the slave if that plastic insert is messed up? I've taken these off 100 times and I've always had issues with mine. I'm not sure if it's just broken or what but I can't get it to budge right now and the plastic ring is pressed all the way in. Last few times I had to disconnect the master and pull it through and I HATED doing that.
So like I just asked, is there an easy way to disconnect the cable WITHOUT pulling the master or pulling the tranny off carefully and unbolting the slave?
Is there any place I can get a new plastic ring for the line?
Old 06-11-2010, 05:10 PM
Billy M's Avatar
We mfg a quick disconnect tool P/N 139080. We also mfg a replacement line kit with steel braided AN-4 line and a roll pin fitting to plug into your factory master P/N 139212.
Old 06-13-2010, 02:31 PM
i wasn't able to find the quick disconnect tool you mentioned on the site. you have the direct link?
Old 06-14-2010, 10:26 AM
Billy M's Avatar
This tool is a component item and we don't list components on our website.
Here is a sample of the tool. If you want to PM me with your address I'll send you out one.
Attached Thumbnails hydraulic line to slave-img_0210.jpg   hydraulic line to slave-img_0211.jpg   hydraulic line to slave-img_0212.jpg
Quick Reply: hydraulic line to slave
