need advice for th350 swap
hi i am about to do a th350 in my 2002 camaro but i am not excatly sure what parts i need to complete this swap i know i need the hughes spacer is that iT??? also what is a good 4000 stall for these trannys ?? thnks also will the bell housing bolt completey straight up?
Location: Your girl's back door giving her the long stroke while you're at work
Get the converter built for a LS motor and you don't have to worry about the adapter.
Here is a start for the questions
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/automatic...th400-faq.html
And like gsxr1k2 said; type in "Th350 Swap" on you'll find a **** load of threads about it
