bad valve body????
Old 06-15-2010, 08:21 AM
bad98ls1camaro's Avatar
Default bad valve body????
i was driving the other day, playing around, i nailed it from almost a stop. it spunt through first, when it shifted to second it was like it was in nuetral, the motor jus reved up, i let off and stopped the car. put it in reverse, no reverse, put it in drive, it goes but it doesn't shift to the next gear till i let off the gas, then it will shift, otherwize it will jus tack out and never shift, PLEASE HELP
Old 06-15-2010, 12:08 PM
72blownvert's Avatar
Sounds like a busted sunshell. Its going 1st to 3rd. No 2nd or 4th or reverse.
Old 06-15-2010, 07:21 PM
would you guys rebuild it or or jus change the sunshell for now???
Old 06-15-2010, 08:29 PM
Definitly go through the trans while its out.
Old 06-17-2010, 11:01 AM
98 4X4 burban's Avatar
X2
if it is a sun shell you will have to tear the tranny about 90% apart so it would not make sence to just replace the sun shell unless the tranny had just been rebuilt.
