Pics of new hood and intake setup
Dont know yet, but I DEFINATELY feel the difference with the new intake/tubing setup....maybe the IAT was heat soaked I dont know. It is a good bit cooler now, which means more timing.
I mounted the IAT right above the filter in the pipe.
It stills needs a retune, track testing.
Hard to say if its faster, I changed so much stuff at once....It "feels" pretty good, even with the heat outside...its DAMN hot.
Hell I may have slowed it down, I wouldnt be the first bonehead to do it LMAO.
Couldn't tell what intake your running, but it looks like a single plane intake. I was thinking bout the same set up for later but with the Gm intake since it builds more torque. Plus I think it would be a good setup with the heads I wanna run to later on. I have seen some really good numbers when they did run it on stock setup with the hot cam.
