turbo mount to cage in malibu?
Old 06-19-2010, 04:24 PM
leonpiper69's Avatar
Default turbo mount to cage in malibu?
i have a cage in my malibu and i took my ls1 out of my mustang and am putting it in my 78 malibu. i got a 72 mm turbo im going to use and am trying to decide how to mount it.
im thinking about welding a plate to the cage bars to mount to, but im not sure on the rules. i know i cant drill holes in the cage but other than that i dont know much.
anyone got any suggestions and or pics of what they have done?
see if i can find a pic of my engine bay to show cage.
Old 06-20-2010, 09:32 PM
rotor vs. piston's Avatar
Unless your engine is on solid mounts you can't mount the turbo to anything other than the engine. It will crack the manifold at best, weaken anything you mount it to at worst.
If the turbo is that heavy, make a bracket to bolt it to the engine.
Old 06-20-2010, 10:37 PM
[QUOTE=rotor vs. piston;13495727]Unless your engine is on solid mounts you can't mount the turbo to anything other than the engine. It will crack the manifold at best, weaken anything you mount it to at worst.
duh! thats kinda obvious.
im trying to decide if i want to run solid mounts or not. i did that in my 70 camaro with i blown big block and didnt really like it.
im more interested in pictures of how people have set up theres and rules of attaching things to the cage.
so ROTOR, how did you set up yours? did you mount it to a bracket on the engine or a bracket on the cage? do you have any pictures to share of how you set yours up?
i wouldnt crack a manifold, im making my own headers.
Old 06-21-2010, 04:47 PM
agreed, it's a "duh" answer, what's surprising is how many times it IS the answer.
If a turbo is hanging off of it, it's still called a manifold, just a tubular manifold. I've gotten my *** chewed about that terminology myself.
Of the turbo engines I've have/had the manifold supported the turbo.
Quick Reply: turbo mount to cage in malibu?
