NEED FAVOR! Need pic of clearance/dist between FAST 90 and Valley Cover!!!
Just like title states, I need a good clear pic of a mounted fast with the pic having the clearance/distance between the bottom of the intake manifold and the valley cover! If someone can take one for me I would appreciate it! I bought a fast that has a cracked bottom and I am needing to know how much room I have to play with cause I plan on epoxying a sheet of plastic on the bottom over the crack. TIA.
Thanks man. The crack is about 4 inches behind the TB opening and runs from left to right across the bottom of the intake, I am going to epoxy in a sheet of ABS plastic and call it a day.
