whinning noise when turning
Old 06-23-2010, 06:11 PM
torqls1's Avatar
Default whinning noise when turning
i hear this normally from new gears. however as far as i know the car was bone stock when i bought it and never put gears in myself..
Old 06-23-2010, 07:49 PM
FatZ28's Avatar
Checked your power steering fluid? Low fluid will make the pump whine when turning.
Old 06-23-2010, 07:52 PM
torqls1's Avatar
its good and its coming from the rear bro
Old 06-23-2010, 09:26 PM
JM0523's Avatar
Mine does the same thing and ive been wondering if it has gears in it
Old 06-23-2010, 10:06 PM
lt1pwr1's Avatar
Change out the rear end fluid and add some posi-additive to it. I got mine at autozone for like $6 and I haven't had the noise since then.
Old 06-23-2010, 10:48 PM
NoTractionLS1's Avatar
Thats exactly what will fix the problem. 90% sure.
Old 06-24-2010, 11:04 PM
torqls1's Avatar
wat fluids you guys use for the rear dif/posi flu
Old 06-24-2010, 11:18 PM
just get Vavoline or mobile1 it doesn't really matter. Unless you obsessed over a certain brand. Then get the additive. Only put 1-2 oz in the diff.
Old 06-25-2010, 05:51 PM
torqls1's Avatar
and how much diff fluid? also how do u change the rear diff fluid in these cars lol undo the bolts on the housing and then the fluid will drain out?
Old 06-25-2010, 06:57 PM
Cam'dandslow's Avatar
Unless you have a vacuum pump to pull through the check plug than yes you need to pull the rear diff cover for the fluid to drain out. You will need at least silicon to reseal the rear cover. As for fluid capacity alldata just specifies to the top of the fill hole i would imagine no more than 2 quarts.
Old 06-25-2010, 07:07 PM
Yes 2 quarts is all you need. And then then add the additive!
Old 08-15-2010, 11:33 AM
nasty_ss's Avatar
so you just mix it in with the fluid?
