RMVB / Transbrake / TH400: All gears go forward.... :(
My transmission will not go into reverse anymore. Before i had to hold the transbrake to go into reverse but felt really loose... Had to rev like 3-3.5k to move.
Well now it feels like i have a constant load on the trans w/ no reverse. Even in park i have a constant load if i get on it.
The trans still shifts perfectly smooth and stays around 160* temp. Every gear im in ( 1,2,3,N,R..) they all go forward.
Any advise?
Th400
RMVB
Hipster Transbrake
trans cooler
temp gauge
B&M 2500 Converter
Any advise?
Th400
RMVB
Hipster Transbrake
trans cooler
temp gauge
B&M 2500 Converter
First thing is to check linkage if that is good it sounds like the foward clutches are fused together or a cross leak.Reverse sounds like its slipping drop the pan look for debris in the pan if so unit needs to come out.
