Need Low profile ramps!
Old 06-27-2010, 04:39 PM
texas99Z28's Avatar
Default Need Low profile ramps!
My Camaro has the RS package, and I would like to find ramps that will work for me without having to take off front bodywork to use them. Any products anyone has used?
Old 06-27-2010, 08:41 PM
I8ASaleen's Avatar
Why not just buy a low profile jack? I have used my AC Delco jack on a car that much lower than an RS Camaro and it worked just fine.
Old 06-28-2010, 07:10 AM
LS14EVR's Avatar
Just make some pre ramps to your ramps. Like a 2X10 piece of lumber or maybe two 2X10 pieces stacked on top of eachother. Make the bottom one longer though.
Old 06-28-2010, 07:25 AM
fleetmgr's Avatar
^^^^^ This is what I use, although mine are 2x6's. 2 pieces, stacked on top of each other. Cut a 45 degree angle on one end, then stack the pieces so the angles provide a smooth transition from one piece to the next.
Old 06-28-2010, 07:30 AM
nimrod.sixty9's Avatar
Same here. Just drive up on some wood blocks and I was good to go...
3 1x4's for each wheel.
GL I know its a pita to have to do that every time but at least its quicker than removing the gFX.
Old 06-30-2010, 03:52 AM
Josh Nickelsen's Avatar
I have to also use some sort of a pre ramp to be able to get up on rhino ramps. I use 2x4's or have even used kids books at times. My car is lowered with the gfx package to it's very low.
Old 06-30-2010, 10:51 AM
qwk93ta's Avatar
I have a set of ramp made for vetts cost about $200.
Old 06-30-2010, 11:48 AM
thatguy383's Avatar
yeah F man, just put 2x4s down in front, ive done that a lot for 3rd gens.
