sway bar size on 99ss????
Judd is right, the front is a 32 mm hollow bar and the rear is a solid 19 mm. I have also put in the ST 35 mm front and added the 1LE 21 mm rear and it really sharpens the handling. Very little bady roll in the corners and it is much more responsive going into and out of corners. When I first got the SS, I felt is was very good in the corners but once I tried Autocrossing, I learned it understeered a bunch going into a corner. I suggest you call Sam Strano at Strano Parts and discuss your goals for your car with him. He post here regularly and also on LS1.com and is a two time National Champion in SCCA AutoX in a f-body.
