Pinion angle?
Old Jan 16, 2004 | 04:22 PM
DanoHB's Avatar
Default Pinion angle?
What pinion angle should I go with on a street driven M6. I don't run at the track so I really don't want it too extreme. I was thinking about -1. Does that sound right with my setup. I also have the LCA relocation brackets, Spohn TQ arm, BMR springs (1" lowered), and Bilstein shocks on the way and will be installing all at once.
Old Jan 16, 2004 | 09:09 PM
DanoHB's Avatar
Anyone?
Old Jan 16, 2004 | 11:04 PM
more carbon's Avatar
Default pin >
Originally Posted by DanoHB
Anyone?
set at 0 or at the most 1 deg. down.
Old Jan 17, 2004 | 01:43 PM
wrencher's Avatar
wrencher
Depending upon what the Degree is off of the trans?
Old Jan 17, 2004 | 03:51 PM
jimmyblue's Avatar
Moderator
The pinion angle wants to match the transmission tail angle.
On a torque arm (and any non-parallelogram link setup) the
pinion angle changes with ride height / compression /rebound.
You would like zero angle difference at normal cruise. Need
to measure the trans angle with the vehicle on the wheels,
and then adjust pinion angle to {whatever that is}.
Most angle gauges are gravity gauges so vehicle rake, springs
etc. will affect absolute angles. Go by relative angle difference.
