Sway bars on WS6
Old 01-17-2004, 12:18 PM
Creed's Avatar
Default Sway bars on WS6
Do the WS6's have upgraded sway bars? If so, are they comparable to the Hotchkis or BMR products (size/strength/weight). Trying to find out if a WS6 would see a significant benefit from buying any of the common aftermarket sway bars.
Old 01-17-2004, 06:57 PM
TaTommyWS6's Avatar
I just upgraded my stock 2000 WS6 sway bars with BMRs solid 32mm/21mm set, and it was worth every penny. It also comes with all poly end links.. My car handles like it is on rails now...
Go for it, you will not be dissapointed!
I measured the stock ones when I took them off. Front was a hollow 32mm and rear was 19mm solid.
Tommy
