Any Prospeed Porsche brake kits left?
Originally Posted by CANNIBAL
This seems like the most cost effective route in the grand scheme of things for:
- Reliability
- Performance
- Access to parts and service
even thoughProspeed uses the same caliper Movit , it is leagues below in fit and finish and engineering of the components as compared to Movit or Stop tech.
just my thoughts after seeing one.
Mitch
I can say my brackets in the front needed no Shims. My park brake caliper needed a a couple of small shims to center the caliper on the bracket though.
The Prospeed brackets are CNC machined and very accurate. The shims are provided because of design tolerances in the oem spindle, not bracketry. If you were able to bolt on a fixed caliper/fixed rotor setup to the traditional GM quality control manufactured spindles with no alignment issues, then god himself was smiling on you that day.
Originally Posted by roy
Hey race you have a pic of prospeeds mount bracket? I am sure they incorporated some changes in later kits.
