Gears & Axles - were all ls1 driveshafts aluminum?
photoman9988
07-02-2010, 07:10 AM
i was told that with a steel driveshaft, i won't make good power on the dyno. my car is a 99 ta. were all ls1 driveshafts aluminum, or just the ws6/ss cars?
gillbot
07-02-2010, 07:40 AM
no, it depends on the gears
2.73 cars got steel, the rest aluminum
BlackScreaminMachine
07-02-2010, 07:52 AM
The difference will be neglible. Unless you want to swap one at the time your dyno'ing, you wont know on your car how much it changes.
Being Steel it is a little stronger and thats a PLUS.
In the end with different cars, they have different drivelines, different weights as far as wheels/tires combo goes so like said, defintly some variation.
01ssreda4
07-02-2010, 09:15 AM
yep, and I dont think it really makes a squat on a dyno.
gillbot
07-05-2010, 08:36 AM
the problem with the steel shaft is the critical speed. if you bump up shift points, the limiter or change gears, you can exceed the safe speed of the steel shaft and cause damage.
07-05-2010, 08:57 AM
I have never seen nor witnessed a Stock Steel DS Grenading at Speed. I ran my 383 LT1 over 130 mph and never had it let go. So take it for what you will and I never had vibration issues.
I did at one point swap it out for a 3" Steel from Denny as it's their Nitrous Ready Unit and the car was HEAVY. I still use it today in my 6 Speed LS1 that pulls both wheels.
We did have TheChef (LS1tech Super Moderator) Grenade his LS1 Aluminum at a track rental trying to leave hard on a 9" 4.10's 5.5k dump. So with that said, it all depends on the situation.
JoshuaGrooms83
01-10-2013, 10:31 PM
guess im glad i got an auto ta with a steel drive shaft. gotta say though, ive never felt anykind of vibration at 100+ speeds. Iv driven my car in germany on the autobahn and 140+ mph crusing speeds was common place with 100mph the normal speed limit at times. my drive line felt fine. now i dont know if my UMI suspention had anythign to do with the stability, but on on stock driveshaft and rearend and a stall and dont feel anything like that. i guess my 98 is just lucky. that or was built on a WEDnesday lol
