any tips for trans removal, poly engine mounts?
Old 07-03-2010, 10:51 AM
mike13's Avatar
Default any tips for trans removal, poly engine mounts?
I've removed my transmission about 5 times in the past first time with poly engine mounts. Trans doesn't hang when you remove the cross member. Any suggestions or tips for the experienced? Looking for tips or tricks for the top bellhousing bolts, usually not to bad with stock mounts, this looks mor challenging.
Jack under the crank pulley?
Old 07-03-2010, 05:36 PM
99Bluz28's Avatar
Do you already have a 24" or longer wobbler extension, and/or tried loosening the pedestal mount bolts?
Old 07-03-2010, 05:41 PM
AFASTYZFR1's Avatar
Buy the correct socket with swivel attached (all in one). Fits up in there better and then just use all the necessary extensions.
Old 07-03-2010, 10:29 PM
mike13's Avatar
Yep, I did end up loosening the pedestal bolts.
