Anyway to remove the clutch master/slave without pulling trans?
Old 07-03-2010, 04:55 PM
GR33N GoblinM6's Avatar
Default Anyway to remove the clutch master/slave without pulling trans?
Im trying to make my clutch master adjustable in my 92 camaro...I am using a 96 LT1 T56...
to do so i need to pull the master cylinder... but im not sure how to remove the slave on this trans.. i see that its bolted down on the driver side... do i just remove those 2 bolts and take it out or is there more to this?? please help ASAP. thanks
Old 07-03-2010, 04:58 PM
RamAir95TA's Avatar
You got it.
Old 07-03-2010, 05:08 PM
ok so i unbolted those 2 bolts and this thing pushes itself out on its own, then when i pulled on it, it seems like its attached to something down in the bellhousing.. the rubber cover is blocking my view to see whats down there.. is there a trick to taking it out? what about installation when im done?
Old 07-03-2010, 05:18 PM
airfix's Avatar
No trick to taking it out. It will push itself out like you described but nothing else should be holding it in.
Old 07-04-2010, 09:11 AM
GREGG 97Z's Avatar
Like Haynes says, installation is the reverse of removal.
Old 07-04-2010, 09:16 AM
wrd1972's Avatar
Both come out easy. Putting the master back in is a little more tricky due to lining it up, lack of acess and visibility and getting the u-bolts back in. But not bad.
Old 07-04-2010, 09:42 AM
Village Troll
SS RRR's Avatar
Because the dust cover obscures your view of the pushrod on the slave extra attention is needed to ensure the pushrod on the slave cylinder seats correctly onto the clutch fork. You'll understand once you put it together.
Quick Reply: Anyway to remove the clutch master/slave without pulling trans?
