Strange Problem Help!
Old 07-06-2010, 07:52 AM
Johnnypappis's Avatar
Default Strange Problem Help!
Ok so my A/C blows warm that I can deal with, easy enough. But when I go to turn the A/C on no matter what setting it only blows out of the footwells and up on the top of the dash pad, it will not come out any other vents. Any Ideas? thanks in advance!
Old 07-06-2010, 09:09 AM
EDS01SS's Avatar
you either have a bad selector switch or your vacuum supply hose to the switch is disconnected somewhere
Old 07-06-2010, 09:19 AM
fleetmgr's Avatar
Check on the back of the intake manifold for the vacuum line.
Old 07-06-2010, 10:15 AM
Default Thanks
Will do when I get off work, Hope it cools down later this northeast heat wave is brutal!
Old 07-06-2010, 10:16 AM
BTW car is a 2002 z28 if that matters at all!
Old 07-07-2010, 07:56 AM
Also anyone know why my left turn signal flashes and the right is solid?
Old 07-07-2010, 08:40 AM
xJakob_00TA's Avatar
You've got a bulb out on you right side. Check your front right blinker, they are notorious for going out. Worst case scenario, you'll be replacing the socket and that's not that bad.
Old 07-09-2010, 09:17 PM
Thanks a bunch everyone!
Old 07-11-2010, 11:51 AM
IROCthisZ28forLife's Avatar
Yeah Ron, the bulb is probably bad. As for the AC, possible also that you could have a clog or stuffed up. Remember I had stuff from woodland creatures everywhere in the Z. Hell I'm still finding suprises
