Driveshaft size
Old 07-06-2010, 08:17 PM
hardtopz28's Avatar
Default Driveshaft size
How do I tell what drive shaft I need. I have a moser 12 bolt I bought second hand and I dunno what the pinion yoke size is and the stock driveshaft is to small. Can I just change the yoke on the drive shaft or is it easier to buy a new drive shaft? Any help will be greatly appreciated
Old 07-06-2010, 09:15 PM
white97t/a's Avatar
Most aftermarket rears will use a 1350 series U joint. I believe stock is considered a 1310 series. There are conversion U joints available but that option is clearly not the strongest. The driveline is only as strong as its weakest link and the 1310 side of a conversion U joint will only be as strong as stock.
Might as well go with an aftermarket driveshaft set up with 1350 series U joints.
Old 07-07-2010, 04:10 AM
hardtopz28's Avatar
Ok thank you. Where is the cheapest place to get one of theses 1350 drive shafts.
Old 07-07-2010, 06:33 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
http://shop.brutespeed.com/PST-35-In...Driveshaft.htm
Check out the above link. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
