Removing MAP sensor plug
does anybody know how to remove this plug. Just got this intake today and the brake booster fitting was broke off. No big deal if I can get it out I can replace with LS1 plug. I can spin the plug but it doesn't back out, so that leads me to believe that I have to pull on it. Just looking for a way to get it out without breaking something on the intake as well that would prevent me from using it. Thanks for the help in advance.
i broke mine too ..
then i use some kind of a super glue to fit this sensor back in without getting any leaking at all
try to do my solution if you can ..
Thanks for the reply.
Yeah we figured we could use some kind of epoxy to glue it back in if we have to. Going to try and cut up one of our spare ls1 intakes to see if we can get at the plug from the inside and remove without breaking it. I guess no one has ever removed this without breaking it or cutting up an intake?
Ive never heard of anyone replacing it without killing another intake. Usually careless shippers dont pad the rear of the intake well enough and the rowdy UPS folks brake the ports off leading to one of these threads
GM lists a PN and seal for it, but it doesnt show to be available
http://www.compnine.com/index.php?u=...00&grouptype=B
