fuel line question.
Old 07-08-2010, 05:43 PM
meinthe73's Avatar
Default fuel line question.
I know it maybe frowned apon,but has anyone skipped the fancy quickdisconnect lines and use fuel injection hose and clamps ? If so have you had any issues. Thankss
Old 07-08-2010, 06:13 PM
Rick Speed's Avatar
You can do that as long as you use properly rated psi and also the correct size fuel pressure clamps NOT hose clamps
Old 07-08-2010, 07:24 PM
Pocket's Avatar
An absolute TON of swaps use clamps atleast somewhere in the fuel system on the high pressure side. Check out the C5 filter thread
Rick is right on the clamps. Hose clamps have a worm screw. Fuel pressure clamps have a collar and a bolt
Personally, Id never skimp on the fuel system or the brakes
Old 07-08-2010, 07:43 PM
LS1MCSS's Avatar
Even though I am running at a low fuel pressure, I have way too much money invested in this **** to trust a rubber fuel line and clamp.
Old 07-08-2010, 08:40 PM
jjbiggers2's Avatar
I have run it for about 10 years at 55psi no problems just have the right hose and you will be fine.
Old 07-08-2010, 10:29 PM
meinthe73's Avatar
thanks for the info guys, now i feel a little better bout using the hoses
Old 07-09-2010, 09:04 AM
crosstraining's Avatar
Where did you get your hose and clamps at?
