Got my headers in!!!
Old 07-09-2010, 01:21 AM
Restricted User
z99ls1's Avatar
Default Got my headers in!!!
I don't see how so many people have problems installing headers on ls1's. It was real easy. Headers slid right in, ory slid on great. Took me a total of 7 hours and didn't really have any troubles. I used my stock metal gaskets, soo I hope they hold up good. Just thought I would rant. Let me know if you got any tips for what I might needa do after there on or stuff I should look for.
Old 07-09-2010, 01:31 AM
ls1whip's Avatar
nice bro, if you drive it alot id occasionally check the header bolts and make sure they havnt loosend up on ya, the metal gaskets should work i guess? lol i havnt herd any one reusing them but yeah im sure people do and if they dont leak who cares! i went with the same set up as you actually, i love the pace setters. mine where a breeze to install of corse i had a lift so i cheated... are you still runnin cats?
Old 07-09-2010, 01:34 AM
Restricted User
z99ls1's Avatar
Nope cats are gone. Should I remove the air box thing?
Old 07-09-2010, 01:39 AM
ls1whip's Avatar
do you meen the air box baffles, the deal that comes off the lid to your maf?
Old 07-09-2010, 02:11 AM
Restricted User
z99ls1's Avatar
No the thing that cools the cats or w/e?
Old 07-09-2010, 08:23 AM
ds98formula's Avatar
Yes take out the air injection and egr. Also get a tune it is not 100 percent needed but it will give you better mpg and smooth it out. Plus you will get a couple more ponies out of it.
Old 07-09-2010, 09:04 AM
Restricted User
z99ls1's Avatar
Yea I have tune now, I am going to get it retuned. It will prob run like **** now since I don't have cats. What will happend if I try to drive the car without any 02 sensors?
Old 07-09-2010, 10:11 AM
ls1whip's Avatar
did you buy the pacesetters w/o the o2 bungs? basically if you drive your car with no precat 02's its going to not have much in the way of fuel trim its goin to run fat all the time the car need's o2's to monitor how much fuel to add or take away to try and keep the car stoikiometric.. the car can use the maf and map and throttle position to try and keep it running at 14:7 to 1 afr. if you take off your egr and air pump again it really depends on which direction your goin are you going to drive this car every day?
Old 07-09-2010, 10:24 AM
Restricted User
z99ls1's Avatar
No I just ment for today tell I get my 02 extensions. I don't plan to run it like this for long lol
Old 07-09-2010, 11:00 AM
udienow's Avatar
I would not run it without any o2's.... better safe then sorry?
I would for sure remove the AIR and EGR assuming u got the race style headers.
Old 07-09-2010, 11:18 AM
Restricted User
z99ls1's Avatar
You wouldnt drive it at all without 02's?
Old 07-09-2010, 11:55 AM
Ls1Rook's Avatar
I drove it without o2s for a couple of days,Only a code came out but turned off as soon as i got my extensions.
Old 07-09-2010, 12:25 PM
DaveX's Avatar
Without the 02's, it will be in open loop all the time and run rich as a safety precaution. It will also typically run rich with headers if it hasn't been tuned for them. So it is probably very rich. I wouldn't drive it much that way.
Headers that fit well aren't bad to install at all as long as you have the car high enough in the air.
Old 07-09-2010, 12:47 PM
TooLateVTEC's Avatar
Nicely done, im glad things went smoothly for you.
Did you have any help?
Old 07-09-2010, 07:03 PM
Restricted User
z99ls1's Avatar
Yep had my dad helpin me. Went really great
