sticky throttle STILL won't go away
i have a 96 lt1 and my throttle is sticking. ive searched high and low but still couldn't find anything that has helped. i've cleaned the throttle body and the blades with carb cleaner, i've scrubbed the inside of the TB with a towel, i've lubricated the throttle cable, and i've also sprayed dw-40 on the blade spring and the hinge on the gas pedal. nothing has helped. it seems to only stick when the car gets up to running temp. and i do not have any SES codes popping up. maybe my throttle cable is just f*cked up or something.. but it's really starting to get annoying. anything you guys would suggest i try before i go out and buy a new throttle cable? the car has ABS and TCS, not sure if that makes a difference or not. any help is appreciated!
i went out and disconnected the throttle cable like you said, and pressed down on the pedal. it took very little effort to push the pedal down, so i don't think the cable is the problem here.
how do you check the alignment of the cable/throttle body? there aren't any kinks in the cable.. and i haven't changed anything about the cable/throttle body since i've bought the car, the sticky throttle body just started happening recently.
