do thye make .060 over 4.8 piston?
Just bore it out to an LS1 piston size. You would have more variety to pic from, and they might be cheaper too. Go on to a more popular vender and they might even have some off the shelf pistons to match the rods you have.
You might as well go ls1 bore ^^^. Its the same block that everyone bores out to 3.898 to make iron 5.7's.
If you're set on the factory piston, a 2007+ 5.3 replacement piston will be the same style - flat top. But if you go that route (if available) make sure to verify its a flat top before buying.
Either way, if he's looking for cubes, or cleaning up something bad, the ls1 bore is the best option IMO.
