head ?
Old 07-16-2010, 05:30 PM
AceHaag's Avatar
Default head ?
Are the 243 heads used on 5.3s any different than the ones used on the 5.7s?
Old 07-16-2010, 05:33 PM
ss.slp.ls1's Avatar
You mean the L33? No, head casting numbers are unique, a 243 head is a 243 head. The only difference their would possibly be is whether or not it has the lighter sodium filled intake vales or not. But for most people, it doesn't matter at all.
Old 07-16-2010, 05:37 PM
AceHaag's Avatar
Thanks I got a 5.3 out a trail blazer and it has the 243 heads so i was going to use them on my 6.0. I may be getting another set also so i just wanted to make sure they are the same.
Old 07-17-2010, 04:04 PM
synisterC5's Avatar
Someone must have changed heads on the 5.3. I dont believe they ever came on a 5.3.
Old 07-17-2010, 07:19 PM
garygnu's Avatar
I was just told they did come on some 5.3 engines.
Old 07-17-2010, 11:32 PM
bww3588's Avatar
the 799's came on the L33, its the same as a 243, just doesnt have the sodium filled valves and i beleive it has a smaller chamber like all the other 5.3 heads.
Old 07-18-2010, 12:52 PM
AceHaag's Avatar
so are the 799's better because i have a set of those too.
Old 07-18-2010, 12:57 PM
bww3588's Avatar
799's and 243's are the same, but the 243's have the sodium filled exhaust valves.
Old 07-18-2010, 01:39 PM
SweetS10V8's Avatar
243s came on 5.3L engines, just with heavy valves.
799s and 243s are also the same.
