Striped BellHousing Bolt! Need Help!
Just put in my tranny and torqueing to specs when the very bottom bolt on driverside began to strip! Luckly it is the very bottom and will be easy enough to get to, but was wandering the best way to go about fixing it? Also what size cooler in inches do you recomend when not using stock oil cooling system, tranny cooler only!
