P&P Throttle body on a 98?
Old 07-18-2010, 04:37 PM
Arc00TA's Avatar
Default P&P Throttle body on a 98?
Is there any issue running a 99 or later TB on a 98? I'm trying to find a nice ported one, but they all seem to be later TB and I don't want to run into a problem with the throttle cable because the cam on the 98 is smaller (hence shorter cable). I searched a bit and couldn't find any info on this.
Old 07-19-2010, 12:16 PM
SShawn's Avatar
I believe it is a different sized cam. If it is you will just need to purchase a different throttle cable iirc.
Old 07-20-2010, 01:10 AM
Arc00TA's Avatar
Could I swap out the cam? Would swapping the cable cause any problems with cruise control?
Old 07-21-2010, 06:54 AM
bww3588's Avatar
98-99 had the same cam on the TB, 2000+ had the larger one. when we did mine, we just tore the TB apart and switched the cams.
