Paint & Body Work - Painting Trans Am bumber
BL96TA
07-19-2010, 04:53 PM
Im wanting to paint the lower portion of my trans am bumper satin black (similar to the berger panel on the camaro but for Trans Am's)
Can i do a quality job with a rattle can? If so what steps should i take prior, during and after. Like which grit sand paper should i prep the surface with? how many layers of paint should i use? do i sand between coats? When im done painting do i need to wet sand? If so which grit?
Anything info you can give me to help me have a quality finish would be appreciated. If it's not possible to get a quality finish with a rattle can then ill just take it to a body shop and have it done that way. Thanks!
9WhiteCamaro9
07-19-2010, 06:11 PM
all i dont with my tail light panel on my camaro was water sand it, primed it, but about 3 to 4 light coats of paint and since i done mine flat black there was those bumps in the paint so then i water sanded them down lightly then put about 3 coats of flat clear on it then i was done but what your talkin about is the CETA mod and theres thousands of threads on here about that mod next time try the search button up top and itll save you time to where you can get it done faster instead of having to wait for replies but i dont mean to sound like an asshole but someone will eventually chime in and say that so i killed to birds with one stone lol
Facelift
07-19-2010, 06:17 PM
Yes you can. I have seen some amazing paint jobs with the can. It all depends on how much time and effort you put into it. If you have never done it before be prepared to screw up. Don't get disappointed, sand, start over again and learn. Have fun.
Blackhawk777
07-19-2010, 07:39 PM
I concur on the rattle can. You can do a good job, it just takes alot more prep work and patience. My center filler is duplicolor universal black and cleared. 2 layers of color, 3 of clear.
http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=308920
BL96TA
07-19-2010, 08:14 PM
Thanks for the replies, im optimistic now that i can get a good result with the rattle can, I didn't know that what i wanted to do on my Trans Am bumper was called a CETA mod so that will help when i search the board. I tried the search before but since i didn't know what specifically i was searching for i had little results. Ill search "CETA" and get the information i need from previous posts. Thanks for pointing me in the right direction!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
