A/C Leak
Old 07-21-2010, 10:21 PM
Hulkamania's Avatar
Default A/C Leak
Hey guys I have a 99 SS that seems to leak out my 134. I was wondering if there was any place on these cars that were notorious to leak in certain spots? I have crawled underneath the car and the pump itself is oily and has green on it indicating the leak. I cant pinpoint it though. Anybody else have this issue?
Thanks
Old 07-22-2010, 07:33 AM
fleetmgr's Avatar
The most likely spot is the compressor crankshaft seal, which is behind the clutch, making it pretty hard to spot. DO NOT RUN the A/C, as on top of being out of refrigerant, you're also now out of oil. The only cure is a new compressor.
Old 07-22-2010, 10:11 AM
slow's Avatar
Also the case seals on the compressor itself leak as well. commonly called a belly leak. I have seen this on several f-cars.
Ryan
Old 07-22-2010, 11:11 PM
Hulkamania's Avatar
Ok so basically I need to pull the stupid compressor, thats so lame!
