Reverse Gone!
Reverse Gone!
Backn the bird in the garage and hear like a grinding sound and can smell burnt paint. Get out make sure no smoke and get back in and won't go in reverse. Damn engine and T56 has only 34K on 2002 WS6 M6. Had a Stage III clutch w/aluminum flywheel put in about 2K miles ago.
Is my syncho shot, something not right with clutch install or?
Yeah all gears forward work fine, just started the grinding noise and burnt smell backing up in the garage on a slight incline.
put it on third and then revert, mind did that too, it only did that first time, and if im put on revert again and again and again it will go in without grind, but first time put on revert it will grind, after that no mater how many time I put on revert it no grind, sound like syncro to u ?
