ls1 4.250 stroke
Generally speaking I would keep a smaller stroke on a road race car, its going to be wound up tight all the time and the motor would be a lot happier with a shorter stroke and less side load on the pistons and cylinders.
What about using that money to just buy a bigger LS block, say like a LS2,7,X etc if you can, that way you get some cubes from bore instead of stroke. I would think a stock LS7 would hold up really well if your wanting a good road race motor. I mention the LS7 because you could probably about buy one of those by the time you fully build and LS1 and put in a Callies 4.250 crank. Although I dont really know the going rate on a LS7
I've located a really cheap Callies magnum II. Other than that my option would be a bottom of the line callies, eagle, or just a stock crank. A callies magnum II aught to be alright for high end rpm if I had forged internals and a lightweight racing valvetrain. Or is that still too much side load?
You do not necessarily need to deck the block. Shorter rods, or better yet, pistons with shorter shirts and higher wrist pin placement should work.
But, to maintain high RPM the motor should be over square (larger bore than stroke), and it would be impossible to achieve that being limited by the 3.9" LS1 bore coupled with a 4.25 crank. You would have a problem getting an LS2 block larger than 4.25 for an over square road racing motor. The crank is probably too big for anything less than an LS7 or LSX block.
For drag racing, well thats another matter.
We do 4.250 strokers a lot but use sleeved blocks with longer sleeves. The big stroke causes power to occur earlier in the rpm range and can make more total power as well but it is a tight fit and you have to know what you are doing. The ones we have run are all doing fine so far after several years.
You mean not a regular postion high like 1.344".
I found a stroker kit with 4.25" is the same price as 4.000" and I thought if it is the same price why not get the maximum if the block permits.
If this will require special none shelf postion compression hight then is it best to go with 4.125" stroker.
Thanks
Thanks
I think with the standard deck non sleeved bock you may want to run a shorter rod with some custom pistons. I've never put one together but you will probably need to do some block clearancing for the rods as well.
Thanks
Thanks
