Oil change light? Oil's new
Old 07-28-2010, 07:26 PM
RedmaroSS's Avatar
Default Oil change light? Oil's new
OIk guys so just changed my oil 250 miles ago, do it every 3-3500k with mobil 10-30 syn including new filter also every time. Took my car out tonight and oil change light on dash comes on goes off after about 40 sec and stays off. Does it each time i start the car which has been maybe four times and stays on the same about 40 seconds each time then off and stays off, any ideas on what it could be i doubt the oil is bad after 250 miles
Old 07-28-2010, 07:38 PM
Moderator
jimmyblue's Avatar
Hold the odometer reset button down for 12 seconds or
so and wait for the light to flash. You're done. Car doesn't
know it got changed unless you tell it.
This info is in the owner's manual.
Old 07-28-2010, 07:49 PM
RedmaroSS's Avatar
That was the first place I started...engine in run 12 sec no flash
Old 07-29-2010, 11:50 AM
Moderator
jimmyblue's Avatar
Key on, engine off, hold it in. I just did this last week.
If the odo doesn't reset then maybe you have a switch
problem. Other than that, the method is the method.
Old 07-29-2010, 12:20 PM
Frost's Avatar
you can do this to reset it as well
key to run
gas pedal to the floor 3 times
key off
key on
key off
key on
key off.
It will be off on the next on-cycle.
Old 11-18-2010, 03:18 AM
ta420nk's Avatar
Sry to dig up an old thread.. I've been seeing this light for about 1000 miles now.. Getting annoying to say the least. Imma give this a try.
Old 11-18-2010, 08:17 AM
Ws6kid.'s Avatar
I can say the Odometer switch works for me also the method frost stated is the one i used to use back in highschool when i was working in a mechanics shop.
