exhaust mounts on magnaflow
NO. there should be original tabs that go into the bracket that is bolted to the frame. THat little bracket im talking about will then bolt up to your new exhuast. Hopefully someone can post a pic of what im talking about. You will need that to mate the exhuast with ease.
i went to the parts store and all they show is the rubber mounts. do you know where i can get those brackets?
i thought i was going crazy. the old setup was pretty odd it had rubber mounts connected to the tips to. the new one doesn't have the mounts on the tips.
