overheating & oil gauge going nuts? Questions inside!
Old 07-31-2010, 02:19 PM
02v8ta's Avatar
Default overheating & oil gauge going nuts? Questions inside!
Today was the first time in awhile i've been in steady no-go traffic for about half hour at least. The temp gauge was reading higher than normal (210ish +) and the oil gauge was dropping to 20psi and shaking at times. Is this normal? Or is there anything i can do? The only thing i'm thinking of doing as of now is replacing the oil pressure switch. I'm not sure about a lower thermostat since my knowledge on them is pretty low. One would make the car run better correct? but go to low or if your car goes through cold winters it'll run crappy?
Some help please.
Old 07-31-2010, 04:17 PM
fleetmgr's Avatar
Put a real gauge on your car to check your oil pressure, don't go by the dash gauge. You don't say what your car is, but if it's newer you can reprogram the fans to come on at a lower temp. If you do a 160 stat, you'll need to this anyway to see any benefit from it.
Old 07-31-2010, 09:18 PM
02v8ta's Avatar
Sorry, the car is an 02 trans am, auto, 90,XXX miles.
Reprogram the fans, how? Any downside, issues with getting a 160 stat?
Old 08-01-2010, 02:31 PM
WS9 Formula's Avatar
you can reprogram your fans with a hand held programmer. i had mine done by my tuner. no issues with getting a lower stat. it keeps your motor running cooler.
Old 08-01-2010, 10:23 PM
fleetmgr's Avatar
Downside is it probably isn't going to pass smog.
Old 08-04-2010, 01:14 AM
cherryelky305's Avatar
check how messed up and clogged your ac condensor is. no airflow means higher temps. unless the thermostat is bad no need replacing it.
Old 08-04-2010, 01:19 PM
bjamick's Avatar
Is the car idling low and missing or something? If so that could cause the low oil pressure.
As for temp make sure the radiator is clear of any debris and trash. Also make sure the air dam didn't come off the bottom of the car.
Could be a number of things but if it's just doing it in traffic like sit and go, then it's prob your fans.
