u1016 loss of comunication with VCM !!!!
Old 08-02-2010, 02:43 PM
elias_799's Avatar
Default u1016 loss of comunication with VCM !!!!
this code popped up when when i started my car
what exactly does it mean and what could be the cause of it ?
also my 2 bar map sensor is not recording boost in vcm scanner, and i know that i hit about 3-4 psi of boost when i was driving the car, so why is it not recorded in the scanner
here are all the codes that i am getting
p0102
p0106
p0645
p0650
p1637
u1016
b0017
u1040
u1000
the car is running in speed density open loop mode, so if one of those codes is maf failure it is ok
also abs is deleted in the car, so that will throw a light too
Old 08-03-2010, 06:41 PM
elias_799's Avatar
ok i think i got the 2 bar problem figured out
can somebody help me out with the u1016 loss of comunication with VCM code ?
Old 08-03-2010, 10:19 PM
LS1TECH Sponsor
foff667's Avatar
It means you either flashed or wrote to your pcm recently.
Old 08-04-2010, 05:38 AM
elias_799's Avatar
that's a big relief. thanks man
Quick Reply: u1016 loss of comunication with VCM !!!!
