th400 help
Old 08-02-2010, 08:10 PM
kliped's Avatar
Default th400 help
hey guys, what year of the th400 trans are you using. i found a good deal on a 70s th400 but i dont know if this is the right one that will work with our cars. by the way i have a 99 ta. thanks for any help
Old 08-02-2010, 08:51 PM
Detroit Gearbox's Avatar
It really does not make much difference. If your building the unit for performance/drag racing, a combination of late & early parts are best. Early planets, late center support, late pump and so on.
Hope that helps. (early units may still have a early high drum, which you will need for the stronger int. sprag.)
Old 08-03-2010, 08:12 PM
kliped's Avatar
ooh, ok, thanks.
Old 08-05-2010, 03:43 PM
cambirdracing's Avatar
they went to a 5 bolt pump in the mid 80's (?), all the rest have 7 bolt pumps. somebody correct if I'm wrong, but I think that they all use the same amount of clutches.
Old 08-05-2010, 04:03 PM
72blownvert's Avatar
The later units seem to have less clutches in foward & direct also they have stamped pistons instead of aluminum pistons.
Old 08-05-2010, 05:50 PM
MASS seller approved
smok'nZ's Avatar
look at FTI and ROSSLER for a th400 i flipped a coin between them
Old 08-06-2010, 07:19 PM
you mean 6 & 8 bolt pumps.
You will want to run alum pistons. Forward can be cut to accommodate 6, simple pressure plate/clutch/steels convert intermediate from 3-4.
Thats why I said your builder will use a combination of late and early parts.
