Header leak something to fixit temp.!
Old 08-03-2010, 07:46 PM
Hanzy98LS1's Avatar
Default Header leak something to fixit temp.!
I've got a pretty good leake comen from the air stem on the header (Hooker lts) and the line were thay bolt together the oval. 2 bolts I think 10mm but Thera spose to be a little metal gasket mine fel aprt there something I can use to put in there around the house/shop to keep it quite for couple days??
Old 08-04-2010, 10:16 PM
Hanzy98LS1's Avatar
So I whent to A Zone to try and find the air tube gasket thay looked at me like I was makin the part up any way that's a zone for ya so I came to the conc. I'm not going to find one at auto parts! I'm going to fabricate one out of some exhaust manifold gasket cut it out and bolt it down should work!
Old 08-06-2010, 08:34 PM
blade2222's Avatar
Try this:http://www.rockauto.com/catalog/rafr...?a=G-autoparts, look under emissions, air pipe gasket. Only place I found it.
Old 08-07-2010, 01:58 AM
BOA279's Avatar
you could also punch them in the face and ask for this:
http://www.autozone.com/autozone/par...er=390636_0_0_
