LS9 gasket on LS1
Old 08-05-2010, 10:10 AM
Big_Bird_WS6's Avatar
Default LS9 gasket on LS1
on the ls9 gasket is made for boost. but we have a stock bore LS1. is the gasket to big for the bore.
stock ls1 3.90o bore.
gasket is 4.100
what do you guys think?
Old 08-05-2010, 11:41 AM
crainholio's Avatar
I think if you have to ask that question, you should probably pay somebody to build the engine for you.
Old 08-05-2010, 12:06 PM
lol. ok sure.
i would say i know a lot about the LS. i just didnt know if there was a "common" rule about head gasket only so much bigger than bore.
Old 08-05-2010, 12:19 PM
pwrtrip75's Avatar
Bigger bore gasket wont hurt anything except increase the combustion chamber size a hair, lowering compression....then again why would one do this anyway? The opposite though... having a too small of a gasket would allow the fire ring to be exposed inside the chamber and get burned up or not compress and seal right.
Old 08-05-2010, 12:50 PM
so to big of bore is fine. to small is bad.
ok thanks
Old 08-05-2010, 05:34 PM
AW794's Avatar
i loled
Old 08-05-2010, 06:36 PM
garygnu's Avatar
you can get some gm MLS for 3.908 bore for less then $50.
