Will hypertech proggrammer do the trick?
Old 01-22-2004, 10:27 AM
lt1zzz's Avatar
Default Will hypertech proggrammer do the trick?
I am in the proccess of installing a hotcam,1:6rr,edlebrock shorties with y pipe,mild head work,trans shift kit and 2600rpm stall converter on my 94 LT1.My question is will the hypertech be aqble to take care of all my tuning needs>oh also have 3:73 and cold air kit
Old 01-22-2004, 12:40 PM
2xLS1's Avatar
No. And your A4 car will not idle with a hot cam without custom tuning. You're not going to see much gain with that 2600 verter either.
You already have 1.7:1 rocker arms stock. I think you need to do a lot more research first.
Old 01-22-2004, 01:05 PM
lt1zzz's Avatar
Hello i have a LT1 not an LS1.Maybe somebody else needs to do some research!!
Old 01-22-2004, 01:08 PM
2xLS1's Avatar
Hey, look up at the top. This is LS1tech.com.
Old 01-22-2004, 01:12 PM
lt1zzz's Avatar
Duh.I realized that,So LT1 guys are'nt welcome or what!!
Old 01-22-2004, 01:20 PM
98SS Blackattack's Avatar
With an A4 its hard to get by with the hotcam. So you will need tunning. The handheld programmers wont cut it. Ls1 edit,Dyno tune or a custom tune are the best bets. I would suggest a higher LSA cam, if you dont want to pay for tunning..
Old 01-22-2004, 04:28 PM
lt1zzz's Avatar
How much does the dyno tuning usually cost.Or where and how much would a custom tune be?
