Rossler 4L80E converter won't lock
I have a 98 camaro with a Yank ss4000 converter and Rossler built 4L80 using his hybrid manual valve body. Both the converter and trans only have 250 miles on them. Since new the converter does not lock nor try to lock nothing happens. I have tested and know the lock up solenoid is getting ground signal to lock and is clicking. I talked to David at yank and he said he personally test all the converters to make sure they lock, so I was just curious if someone knew what direction I should go from here as far as testing and checking for what is wrong. Oh and I'm the second owner so neither trans nor converter have a warranty with only 250 miles. All advice is very appreciated Thanks Troy
