help- car's running rough
Old 08-14-2010, 08:57 AM
LWCS561's Avatar
Default help- car's running rough
i bought this 1991 v6 bird a week ago. Since we bought it, it would normally take two tries to get the car started, and it'd be fine. Then it got progressively worse over the week, at one time taking 4 tries to get it to start. The other day my gf couldnt leave the house because it just wouldnt turn over. It would crank, but not turn over. she went back later on and it fired right up. My buddy n I did a tune up on it last night, and replaced the pcv valve, cap, rotor, and plugs. ( wires were fine). So we got it to fire up on the first try, but the car runs rough. It almost sounds like it's got a cam. When you put it in drive, and attempt to drive it down the street, the car has no power at all, and backfires. We made sure all the wires were routed correctly. The fuel pump is relatively new, and so is the cat. What could possibly be wrong?
Old 08-14-2010, 04:09 PM
09camaro383's Avatar
check fuel pressure i will double check and also swap the fuel filter
Old 08-14-2010, 05:37 PM
99SSJarhead's Avatar
Check your oxygen sensors as well
Old 08-14-2010, 05:39 PM
twitchtwice's Avatar
make sure the wires are snapped onto the plugs. maybe you missed one
Old 08-14-2010, 07:54 PM
mannyman84's Avatar
Fuel pump seems faulty. Usually hard starts are from fuel pumps or clogged fuel filters. Also check vacumm lines.
Old 08-14-2010, 07:55 PM
mannyman84's Avatar
Also a bad egr valve can make your car idle nasty
Old 08-14-2010, 08:00 PM
LWCS561's Avatar
how do i replace the fuel filter? i havent done one on a third gen.
Old 08-14-2010, 08:59 PM
mannyman84's Avatar
It's right under the car like in the middle. Not sure if passenger or driver.
Quick Reply: help- car's running rough
