Couple intake questions...
Got a FAST 102 i am putting on a 02 Camaro, and had heard some issues with getting it to fit without massaging the firewall?? And MAP location? Im sure if i run into this i can fix with ease but just curious as i am almost done with the motor just waiting on heads to show up, and just wondering what to expect..
And, has anyone tried to run the 90mm TB on the Intake? Just because i have a brand new one laying around.. I bolted it up and the gasket on the intake is hanging out a little which will not seal.. So has anyone seen a adapter plate?
this.. and x2 on selling the 90 for the new 102.. if your going to get a huge intake you might as well get the throttle body to supply the most air to it.. as well as thinking about upgrading the rest of the intake tract if you haven't yet (lid, maf, FTRA/SSRA/CHRS1313 etc.)
Waiting for u to chime in lol I will massage it, not gonna hack my **** up like someone elses that rolls around
it is for sale, it's in texas member's.. I just had it laying there from the vic jr setup i was doing.. U would be suprised at the difference in flow between the two.. Yes it flow's better but worth not the hassle to buy another, i will get the other when this one sell's.. Have the better lid and the maf is laying on a shelf, as this setup is speed density..
Main Question was where did u use the bfh.. And was ur placement of maf in back or front?
Do a Little research u will find this issue.. I have put plenty on in the past, 78,90,92 with ease but the 102 is now made by RHS and is alot bigger and different design..
