Couple intake questions...
Old Aug 16, 2010 | 08:58 PM
n20kid's Avatar
Default Couple intake questions...
Got a FAST 102 i am putting on a 02 Camaro, and had heard some issues with getting it to fit without massaging the firewall?? And MAP location? Im sure if i run into this i can fix with ease but just curious as i am almost done with the motor just waiting on heads to show up, and just wondering what to expect..
And, has anyone tried to run the 90mm TB on the Intake? Just because i have a brand new one laying around.. I bolted it up and the gasket on the intake is hanging out a little which will not seal.. So has anyone seen a adapter plate?
Old Aug 17, 2010 | 05:25 PM
brian_rs/ss's Avatar
just use a BFH, it'll fit.
and sell the 90 to help pay for a 102.
Old Aug 17, 2010 | 05:30 PM
smok'nZ's Avatar
MASS seller approved
i had a 102 it fit w/o a problem and when i bolted my 90mm it didnt fit either it would idle at 2500 and when i put the 102 on there it solved it i have seen people using a 90mm but they were all gm elec ones
Old Aug 17, 2010 | 07:30 PM
djfury05's Avatar
this.. and x2 on selling the 90 for the new 102.. if your going to get a huge intake you might as well get the throttle body to supply the most air to it.. as well as thinking about upgrading the rest of the intake tract if you haven't yet (lid, maf, FTRA/SSRA/CHRS1313 etc.)
Old Aug 17, 2010 | 11:25 PM
n20kid's Avatar
Waiting for u to chime in lol I will massage it, not gonna hack my **** up like someone elses that rolls around
it is for sale, it's in texas member's.. I just had it laying there from the vic jr setup i was doing.. U would be suprised at the difference in flow between the two.. Yes it flow's better but worth not the hassle to buy another, i will get the other when this one sell's.. Have the better lid and the maf is laying on a shelf, as this setup is speed density..
Main Question was where did u use the bfh.. And was ur placement of maf in back or front?
Old Aug 18, 2010 | 07:30 AM
SweetS10V8's Avatar
Ive never heard of the FAST intake not fitting on any F-body. My brother put one on his without a problem.
Old Aug 18, 2010 | 09:44 AM
n20kid's Avatar
Do a Little research u will find this issue.. I have put plenty on in the past, 78,90,92 with ease but the 102 is now made by RHS and is alot bigger and different design..
Old Aug 18, 2010 | 04:50 PM
garygnu's Avatar
the fast 102 intake mite not fit under a strut brace.and a ls1 fuel rail won't work on them .the map sensor can be mounted on top of the intake in front.
Old Aug 18, 2010 | 05:00 PM
god damn it why did they have to stop making the 92
Old Aug 20, 2010 | 11:23 PM
smok'nZ's Avatar
like i said too my fast 102 fit fine, only thing was had to grind the waterpump down to get the 102mm tb on there
Old Aug 21, 2010 | 10:08 AM
Dewman's Avatar
only took maybe 3 minutes to grind down the water pump for mine to fit perfect.
