LSL cam lobe base circle?
Anyone know the base circle diameter(s) for these lobes? I'm most interested in the 13014R, 13015R, 13016R, 13017R & 13018R lobes. Thanks for any help!
I asked Comp Cams and got the following response. Just thought I'd share:
From COMP Cams Technical Consultant:
"There is no standard base circle size. It is dependant on what core the cam
is ground on and how far into that core we have to grind it. To get a
general idea you can take lobe lift x2 and then subtract it from your
journal diameter. This will get you somewhat close."
