5.7 iron block build advice
Hi everyone, I am new to this forum, thanks for reading. I am putting together a parts list and would like an experienced Ls builders advice if I am going in the correct direction. This motor will be going into my Nissan 240sx. I am shooting for around 400 rwhp it will be paired to a M6 (T-56)Transmission.
Bottom End:
5.3 LM7 Iron Block bored to 3.989 (5.7)
I will Replace: Main bearings ($20)
Clevite Camshaft bearings ($20)
Connecting rod bearings ($40)
Forged Flat top pistons and rings (Ls-1) ($600)
Gaskets ($150)
Machine work ($300)
Ls-2 oil pump and chain kit ($350)
Vengeance racing stage 1 camshaft 226/228 .585/.588 114lsa 113icl ($389.00)
I will Re-use: Crank shaft
Connecting Rods
Top End:
OEM 241 Heads
I will Replace: Comp 928 valvesprings ($160)
Comp Push rods ($105)
I will Re-use: All other OEM Head parts
Bolt-ons
Long tube headers ($800)
Cold Air Intake($100)
Tuning at F-Body Central Baltimore, MD
Bottom End:
Gaskets ($150)
Machine work ($300)
Connecting Rods
Top End:
OEM 241 Heads
Bolt-ons
Thank you, I am getting the crank balanced, I lumped that into "machine work", I will add head studs to my list, those katech rod bolts look nice, I am debating if I should replace used rods with eagle h-beams to match the new forged piston , I don't know if its overkill and worth the extra $ if the stockers are strong enough.... and edit on my cam I am getting the vengeance VRx4.
Okay so head bolts, main side bolts, and balance bolts are all tty and need to be replaced. I would just buy a LQ4 block if I was going 6.0 and put my 241 heads (which I have) and raise the compression. The problem with that is its going in a 240sx and correct me if i am mistaken, I am not sure if the accessories will fit the same as a Ls block, I would have to do more fabricating... there are pretty much bolt in kits for a LS motor into 240.
I have done some research on the LQ4/LQ9 and that looks like a great way for me to go, with the money I would spend having the 5.3 machined/re-built, I could buy a low mileage LQ, I will use the LQ shortblock and put my 241 heads on it. VRx4 cam, comp 928 springs, and a tune. I am on the hunt for a shortblock and taking my heads to be cleaned today. I have a spare complete LS-1 motor with 3 broken rods and a hole in the block , thats why I am doing this. FYI
