Docked Wage
08-27-2010, 09:08 AM
This is my first post but I've been ghosting for a while gathering info from here and the rest of the web. The reason I've been hanging around is I'm getting ready to do a 5.3 conversion in my 1992 Jeep Wrangler. In my search for a motor I've been to salvage yards and had the opportunity to look at some of junk :barf: for sale on craigslist. After going out and looking at six different engines and walking away from all of them I decided to make this checklist to use while I continue my search:
5.3L "Take Out" Engine Specs
VIN Number from donor vehicle - Either a copy of a title, proof of insurance, registration or some confirmation of ownership or transfer. No VIN, No deal. VIN Provided will be cross checked to engine block. A bill of sale will need to be provided. For person to person transactions complete page 2.
VIN# __________________________________________________ _______
Engine should be a 2003 or later build Earlier engines had issues with piston noise. Verify on the vehicle build date or use VIN Date Code. VIN Date is position #10 in the 17 digit code. X=1999, Y=2000, 1=2001, 2=2002, 3=2003, 4=2004, 5=2005 6=2006, 7=2007, 8=2008, 9=2001, A=2010.
VIN Date Code or build date _______________________________________
Engine must be fully dressed Meaning engine was pulled in a running condition. With the exception of cut hoses it must be complete and unmolested meaning all accessories have not been removed such as:
Power Steering Pump
Alternator
Idler Pully
Tensioner
Exhaust Manifolds (Truck preferred)
Intake Manifold
Injectors
Coils
A/C Compressor. If it's there I'll use it and convert it to an Onboard Air Compressor.
Note: A Longblock with a pile of parts and a bag of bolts is not preferred and will be carefully considered.
Complete Wire Harness Must be uncut with all connectors still on it with everything from the engine to the ECM. Harness should be in it's factory configuration (unmodified) also.
Transmission Harness - For 4L60E. Also includes the rear O2 Sensor connector(s).
OBDII Connector and Harness From under the dash. Needed for future diagnostics.
PDB Power Distribution Box (Underhood Fuse/Relay box) with fuses and relays installed and unmolested.
ECU Confirm ECU is correct for the Reluctor (Gray = 58 or Black = 24) and Drive by Wire. Gray (58 tooth) reluctor sensor engines are not compatible with drive by cable setup. Truck Ecu's part numbers by MY are: 2003 = 12576106, 2005-2006 = 125862432 or 12583560, 2007 = 12597121. Confirm ECU matches the plug.
Oxygen Sensors Low mileage engines only. High mileage should be replaced with new.
MAF Mass Air Flow Sensor. Confirm Wire Harness is intact also.
Exhaust Down Pipe At minimum a section from the Flanges to 3 past the O2 Bung for both RH & LH.
Accelerator Pedal & TAC Module Only if Drive by Wire. Avoid pedals from adjustable height systems. 2005+ Pedals have integral Tac Module. Other years are separate and there are numerous combinations.
Page 1 of 2
Seller Statement:
I hereby confirm that I am the rightful owner of this engine assembly and all supporting components listed on page 1 and that I have full rights to sell to the purchaser. I assure that all of the items presented to the purchaser have been removed only from the vehicle (VIN #) listed on page 1.
VIN # __________________________________________________ ________
Sale Price __________________________________________________ _____
Name______________________________________________ _____________
Address __________________________________________________ ______
Telephone_________________________________________ ______________
Seller Signature/Date______________________________________________
Purchaser Statement:
I hereby agree to purchase this Engine Assembly and all supporting components listed on page 1 and agree that the items are being purchased AS IS and with out a warranty of any kind.
Purchaser Signature/Date___________________________________________
Note: One copy to Seller and one copy to Purchaser.
Page 2 of 2
Power Steering Pump
Alternator
Idler Pully
Tensioner
Intake Manifold
Injectors
Coils
Page 1 of 2
Seller Statement:
Page 2 of 2
