clutche engagment issue
Old 08-29-2010, 01:03 PM
massconfusion's Avatar
Default clutche engagment issue
well i just got my car put back togather and i m having problems with the clutche engaging all the way. I had installed a monster stage 4 500 miles before i blew up the motor. put all back togather and bleed the **** out of it and is still causing me problems. When i first start driving it the clutch will be good for two maybe three uses and then gets soft and doesnt want to engage. Do i still need to bleed it more, perhaps with a mity vac or is it a bigger problem like a master cylinder/slave cylinder?
Old 08-29-2010, 08:01 PM
just drove the car some more, sometimes after the pedal gets soft pumping it a few times seems to help, thinking the master cylinder. I m gonna try bleeding one more time with dot 4 fluid in case it is boiling over but i think the master is bad, anyone know a sure fire way to tell
Quick Reply: clutche engagment issue
