Bolt pattern and back spacing.
If your running a stock length rear in your car to run 15x8 welds you will need a 5.5" backspacing, for 15x10 you will need a 7.5" backspacing and for the fronts 15x3.5 you will need a 1.75" backspacing and the bolt pattern im pretty sure is 4 3/4.
