Anyone know the exact specs on Piglet cam??
12 Second Truck Club
I need to change out my vlavle springs and degree the cam in to try an eliviate my power drop off problem. I have a guy thats gonna work out the math and degree the cam, choose the springs and adjusst preload etc. But I need the complete specs for this cam if anyone knows them or knows who I can call to get them I'd aprieciate it.
I believe the basic spec is 223/.589/112.
Re: Anyone know the exact specs on Piglet cam??
the piglet is a single pattern 223 cam. I'm not sure of the exact specs, but comp 26918 springs should support it just fine. It's under .600 lift for sure.
I have 918s on there now but was told that they might not have enough pressure for such a fast ramp rate and high lift. I was thiinking I might have to go with double springs. Otherwise I dont understand why power stops at 5,500rpm and stays flat till rev limit @ 6,700. I only wanna take this apart one more time so thats why I was researching springs and such if I am going to degree the cam too. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
