Blown Head Gasket
It starting overheating all at once. I have checked the TS and replaced the water pump. I do not see any signs of water in the oil but I am losing water with no leaks.
How can I tell which side is bad or leaking?
Bill
Bill
You could get a coolant pressure tester and apply pressure to the system and see if any of the cyc fill up. Check spark plugs for corrosion or coolant tint to the plug. They also make a kit to check for combustion leaks.
http://www.amazon.com/Lisle-Combusti.../dp/B0007ZDRUI
Bill
You ever figure it out? My car stated to do the same thing yesterday, over heating out of no where, with no sigh of a leak. I checked the oil on the dipstick and it was clear like new oil, which I expected since I did an oil change 3 weeks ago.
blown head gasket
i have a problem also but not sure how to start a new thread, 2001 ss camaro 6-speed. bought in az drove back to ca no problems. seen weird brownish color in overflow tank, took radiatior out of a 2000 ss flushed it and installed a 165 thermostat. was driving and started spewing fluid out of the overflow? the car will not do that if i have the heater going full blast. i started it today left it running without the rad cap on stayed at 210 like normal but started bubble over turned off the car and started spraying out of the radiator. again the car will not do that if i keep the heater on. it only starting doing it after i replaced the radiator, thermo, tranny cooler and the power steering tube all parts off of a 2000 with 28000 miles. also did the coolant test with the blue fluid to check if there where any gasses leaking into the coolant system it was good.
please help
please help
please help
please help
Makes me wonder if your fans are kicking on? Check that first.
IF the you put a 165 stat in the car and you did not have the pcm retuned to have the fan settings come on earlier, your cars fans will never come on to cool the fluid in the radiator. How ever you are doing minimal cooling having the blower motor cool off the fluid coming thur the heater core. Put a stock thermostat back in the car. (2) 10mm bolts and see if you are still having the same problem'
Those fans should come on regardless of thermostat, I think it's around 225 and the off by 215. If you swapped the radiators (regardless of how much we try) then there WILL be air in the cooling system. Hot air expands, blah blah blah. How many times has the engine completely warmed up and how times have you topped off the radiator and reservoir after an overnight cooling? Squeezing top radiator hose helps air bubbles come out, so does rocking the chassis.
