T56 swap to Automatic
Old 09-06-2010, 02:01 PM
zickls1's Avatar
Default T56 swap to Automatic
im looking to swap out my t56 to a 4l60e transmission on my 2000 camaro i was wondering what parts would i need to make it automatic witch is most least expensive rebuilding my t56 or going a4
Old 09-08-2010, 09:56 PM
blackhawk0251's Avatar
I'd have to say going with the auto is going to be the cheaper route.
If your going to pick up any parts Id recommend a high strength flexplate, a good brand of transmission (I run a Performabuilt lvl 2 4L60 and love it) and of course your pedals, shifter, and auto wiring harness
Old 09-08-2010, 10:23 PM
Kevin01Z28's Avatar
It would definately be cheaper to just rebuild your manual than to swap to an auto. A good built auto will cost you around $2000, plus the core charge since you dont already have one. Billet converters run about $700, or you can get a cheaper one. The actually parts for the swap you should be able to get secondhand pretty cheap. You will also need your pcm reflashed, not sure if you can tune or not. Depending on what kind of shape your m6 parts are in will determine how much you can get for those parts. Im guessing if your considering rebuilding the manual they aren't in the best of shape.
Your best bet would be to find someone that has an auto and wants to swap to a manual so you could work out a deal. Then it may be cheaper to go the auto route.
Old 09-08-2010, 11:59 PM
RedRallyeZ's Avatar
i actually start my swap going 4l60e to t56 sunday, as far as which ones cheaper, we may be able to mak some trades....
